Hobo128
- Messages
- 302
Called to job, customer reports that the f and e tank has started to overflow. Went into the loft and f and e tank was full of scolding hot water. Ran the bolier and every couple of minutes the open vent pipe would spit out boiling water.
I have this down to sludge in system and possibly pump set to fast. Also maybe the thermostat on the boiler is on its way out.
I want to know if anyone has had this before and also is there anyway to test the thermostat on the boiler (it's the type with the copper probe inserted into the cast heat exchanger)
