- Messages
- 10,442
Is that not a different fitting though?
Discuss Good or bad idea - would you like it and be Interested in? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes cant find the one I have but it's a similar fitting. However I'm out now getting too much .. not worth the stressIs that not a different fitting though?
I'm not but don't get me wrong though wouldn't it be better to props sometimes some other engineers? It doesn't come across really good either just point out. If I wanted I could also find stuff which should be changed or amended. However, I'm very happy with the works. I would also change a few things but sometimes the quote doesn't allow for doing better works as I am not going to pay from my own pocket.Dont take it to heart Ron our Shaunie will always find something mate he doesn't mean it in a malicious way just has a eye for the slightest imperfection , as long as your happy with your work and abide by the regs and manufacturers instructions then your all good. Cheers kop
But you’ve done the whole install in press fit mate?? That’s about 10 times the price compared to an end feed fitting?I'm not but don't get me wrong though wouldn't it be better to props sometimes some other engineers? It doesn't come across really good either just point out. If I wanted I could also find stuff which should be changed or amended. However, I'm very happy with the works. I would also change a few things but sometimes the quote doesn't allow for doing better works as I am not going to pay from my own pocket.
That's correct beneath the boiler it's done in crimping fittings. It's more expensive but a lot safer, faster and last a lot longer. Don't get your question though?But you’ve done the whole install in press fit mate?? That’s about 10 times the price compared to an end feed fitting?
You said you couldn’t stretch the budget yet you’ve used the most expensive fittingsThat's correct beneath the boiler it's done in crimping fittings. It's more expensive but a lot safer, faster and last a lot longer. Don't get your question though?
The seal is just a double protection. The older fittings used be sound without being crimped but due to some incidents over the years they changed the fittings and did the sc contur which helps to see if you crimped a fitting or not ( obviously ones pressurised ). It will literally spuirt all over the place.Last a lot longer.....eh??? Soldered pipework will out live neoprene o rings hand on foot!
That's the way I plumb. I chose Latest technology which customers like. No one has ever said that plumbing is cheap. I don't do cheap but quality.You said you couldn’t stretch the budget yet you’ve used the most expensive fittings
I get your point but I talk to the customer before I quote and obviously find out there budget to start with. How often you go quoting and it turns out people haven't got enough budget its literally a waste of your time and petrol. I'd rather know beforehand where I am at with the customer. I don't currently corners neither do I RIP anyone off but make sure the customer gets what he agrees and pays for.I’m not criticising I like using pressfit as well but when you are having to save on other parts of the install because you’re using expensive fittings it just doesn’t make sense
You and your contest show me some of your installs darling I'd be really curiousWhy is it safer Ron? Man has been soldering pipes underneath boilers since lpg has been around. Faster!! ... probably not by long, compared with soldering. I’d like to see one of your installs, where you ain’t got a blank canvas and you’re swapping out a boiler connecting onto pipework in a tight area, I’d absolutely floor you with speed and neatness... lovely pulled bends
Reply to Good or bad idea - would you like it and be Interested in? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
