Discuss Gravity feed hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I’m fitting a ‘gravity feed’ hot water tank in a mobile home that has restricted head height for a cold gravity feed header tank. I can install an expansion over flow to an outside drain. Is it possible to use a Pressure Reducing Valve to supply the cold water from the mains supply. Or is there any other way to supply the cold.
Reply to Gravity feed hot water tank in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
