Discuss Gravity solid fuel with remote cyl + oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Elverstown
Hi all,
looking for some practical guidance, went to a bungalow to quote on relocating and upgrading oil boiler and controls. Found; 30+ year old house which originally had a Tirolia solid fuel cooker/boiler (now a Stanley stove boiler) with 1 in (28mm) copper rising to attic and traversing about 3m and dropping to single coil cyl. and to feed rads with pump, return going underfloor to S/F. Oil teed in under cyl. with its own pump. haven't been in the attic or checked for non return valves, but noted that pipe stat for S/F pump was beside cyl, with a manual switch. Houseowners switch on pump as needed / related to the amount of fire in stove.
I was a bit concerned with this layout, oil added about 20+ y. It's working for the owners. do you; if it aint broke, dont fix it, walk away, recommend relocating dual coil cyl. or?
cheers
Thanks Simon, h2 is new to me, looked it up, scheme with buffer overhead makes sence, but panel and tank would be expensive addition to something that is working already, have used Systemlink many times,
What would you do to the job if the set up was in your house, do the same here.
Hi all,
cheers
Thousands of houses like this in NI
Reply to Gravity solid fuel with remote cyl + oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
