Discuss Grecnstar 28i Junior fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gibo348
Hi
Woke up to no hot water or heating (not that I need it) No pressure in system so filled it then reset the system.
Blue light still flashing and when i turn on the hot tap it doesnt even try to spark up- same for heating
Cant see green light for flame also
Any thoughts would be appreciated
You need a Gas safe eng I'm afraid
Why do you say that?
As a non gas safe eng all you can do is top the pressure up and as the blue light is flashing there's a fault
And please read the rules :)
Reply to Grecnstar 28i Junior fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hello, I have a Bosch 35CDi, and today found all the lights flashing on the front. Normally I can reset the boiler, but this did not work. There...
Deleted member 120897
A
Gloworm FF50 both the reset and burner lights are flashing and just buzzing, not firing up. Currently no hot water or heating, everything was...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
I need some help with a Worcester Junior 28i gas boiler and I'm hoping someone here may have came across this fault before ... I have checked...
1K
