Discuss Green ' gunge ' on pipework. in the Central Heating Forum area at PlumbersForums.net
Can anyone explain what is happening to the pipework in a relatively new boiler in the attached image?
Fibre washers leaking needs a gas safe engineer with two Worcester fibre washers
No this wouldn’t sounds like you have a sticky timer or miss wired maybe needs investigation
Reply to Green ' gunge ' on pipework. in the Central Heating Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
