Discuss Greenstar 30 CDi every panel light flashing in the Central Heating Forum area at PlumbersForums.net
Hi, came home to this tonight. Boiler had been running fine, no problems at all. As no heat or hot water went to check boiler and it was lit up like a Christmas tree! No buttons functioning. Switched it off and on. Any idea? No fault codes given just every light flashing. Cheers.
  • E92BEFC2-EDBC-4CE8-8BBF-2E95382B0D8D.MOV
    32.1 MB
Pcb or power voltage incorrect at fused spur most likely best get a gas safe engineer out or fixed price repair from Worcester
Reply to Greenstar 30 CDi every panel light flashing in the Central Heating Forum area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
