Discuss Groaning Expansion Vessel in the USA area at PlumbersForums.net
The tundish near the expansion vessel started dripping, plumber came and pumped up expansion vessel and dripping stopped, great.
However now, every time we flush any of the loos we get a strange heavy vibration noise through the expansion vessel for 1-2 seconds. We also recently discovered it’s worse when turning the outside hose on and off. Attached is a video of me turning the hose on and off in order to reproduce the noise for your lovely ears.
Plumber isn’t really sure, does seem like a water pressure issue. Any help is appreciated.
Too much pressure in the expansion vessel. Needs to be 0.2 bar below incoming pressure, sometimes i've had to do them lower than that to stop groaning etc.
Get your G3 engineer back to check incoming pressure and set accordingly. Don't forget system has to be depressurised to get correct setting on expansion vessel.
Reply to Groaning Expansion Vessel in the USA area at PlumbersForums.net
