Discuss GROHE smart control tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi just purchased above tap it has 19mm flexi tails and want to fit to a standard 15mm isolation valve.
Is there an adapter available as isolation valve is male type, so 19mm flexi needs to screw onto standard 15mm coupling.
Any advice appreciated.
I don't know what screw caps are.
The spec says G3/8" and I've done enough Grohe stuff to know thats what they normally are.
Is your pipe work 22mm?
yes 22mm so your right its just a 22mm male connector to 10mm flex adapter just found 1 on screwfix. I will use the screw nuts from a couple of straight connectors I have spare to connect the small piece of copper pipe to 22mm male connector cheers
I think OP is talking about measurements in mm across the fitting - which we all know has nothing to do with what they are called in bsp or G as they get referred to nowadays.
I think you’re both talking about the same thing.
Reply to GROHE smart control tap in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
