Discuss Grohtherm Wireless Shower - gravity fed to mains fed change? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Heleng
We have the Grohtherm wireless shower for gravity fed system but are just about to have a new system boiler and megaflow system so our current shower will not work.
Does anyone know if you can disable the pump so it will work on a mains water system instead as we really cant afford to replace the shower.
Hlen
You may be able to at a push, fit 2 pressure reducing valves on the hot and cold inlets, set to below 1 bar static pressure and disable the pump but it would invalidate any manu warranty which won't matter much as you won't be able to use it otherwise.
But i is not a shower i am familiar with. Go with what your plumber says.
id see if it works first supplies will still be balanced or ring grohe's for advice may be some flow regulaters available
Reply to Grohtherm Wireless Shower - gravity fed to mains fed change? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
