Discuss Grundfos 25-80 Pump - Magna1 versus UPS2? in the Oil and Solid Fuel Forum area at PlumbersForums.net
Max
Replacing boiler and will be fitting Grundfos 25-80 Pump (recommended by pump sizing calculator). Any thoughts or advice on Magna1 versus UPS2?
From what I can see the Magna1 is a large beast but space not really an issue for me, but is it actually worth it? On paper specs look quite similar.
Boiler will be Hounsfield Tuscan jetted to the full 32kW. Reason I was considering Magna1 is my load will be very variable, all the way from just DHW cylinder to full 4bed/4 bath heating + 3 single panel rads in outbuilding. I wondered (from your experiences rather than just datasheet) if Magna1 handles wide load variations better? Unvented system.
Thanks for looking.
Magna 3 with dt sensor will vary the speed to match the difference or keep it simple grundfos 25-80 or wilo 25 1-8
Don’t rate the alpha pumps goodly
Reply to Grundfos 25-80 Pump - Magna1 versus UPS2? in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
