Discuss Gurgling Noise From Rad When System Drained F&E Empty And Boiler Off in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My heat only gas boiler is drained from the boiler drain valve - There is no water in the F&E tank. The hot water vented cylinder is removed. So far so good
Twice this evening I heard radiator gurgling noises which frightened the life out of me
I cant seem to reproduce the noise and I cant get to sleep thinking there will be one hell of a flood!
Boiler is off from mains fuse so pump will not run and yet I heard the gurglig noise twice from two different radiators
How can this be possible? Many articles link to airlock in a filled system but have not seen this being mentioned on an empty one!
Reply to Gurgling Noise From Rad When System Drained F&E Empty And Boiler Off in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
