Discuss Hansgrohe Axor Y Tap Cartridge replaced in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Best bet is to ring them at £618 a set I'd be nervous about marking them too!
I have replaced cartridges in a few of these at a business premises. They really are a pain in whatsit.
The covers do just pull off. You need to get a very thin bladed screwdriver between the cover and the body and carefully twist it to seperate them. Once you have moved it a couple of millimetres you will find it pulls off quite easily.
Do as I did and warn the customer that there is a possibility of slight damage to the poor design. Although, if you are careful it shouldn't be a problem.
Just removed one so I could replace the Spindle Flow Cartridge. It was quite challenging to get the Chrome Cap off, but in used two Electrical Screwdrivers in the gap 180 degrees apart. Once I managed to create a small gap I could slowly lever the cap off. Very tricky.
Reply to Hansgrohe Axor Y Tap Cartridge replaced in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
