Discuss He24 - removed rad now won't work at all in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I removed a radiator downstairs to wallpaper when I put it back on the he24 will not fire up at all and shows an error code L9.
The pressure had dropped to 0 so I refilled the system. This happened when I removed a radiator before but last time I shut off all the rads except the one I had removed and fired the system while bleeding it which worked. Sadly this has not worked this time.
I am getting water from all of the rads when I bleed them.
The casing of the boiler does feel quite warm.
Help.
Air lock close all the rads except the closest to the boiler upstairs and then turn the heating on will heat the pump working should move it
Tried this earlier but nothing was happening. When I tried to fire it up just got the L9 code again. Will give it another go now it has all cooled down.
You sure you have pressure in the system eg around the 1-1.- bar
Reply to He24 - removed rad now won't work at all in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
