Discuss Heat Interface Unit Advice needed in the Central Heating Forum area at PlumbersForums.net
Hello all,
This might seem like a stupid question, but i have a problem with the heat interface unit in my flat and the block management are not able to provide help in this instance.
Would a normal central heating engineer be OK to contact? Just from looking in the yellow pages or local tradesman there are lots but they all mention boiler repairs and servicing, but not specifically heat interface units in there description of services they offer. Is this something i have to find a specialized person or company to deal with? Or will any local heating engineer be OK to be contacted?
The block management were obviously my first port of call but on this occasion they do not have anyone that is available.
Thanks in advance for any advice
Just contact several reputable firms and ask if they have any experience with Heat Interface Units. I wouldn't suggest letting any old person look at it, if they don't have the knowledge or experience they could potentially cause more problems than you started with. There are a few on this forum with lots of experience in this area so you might want to explain your problem in the hope someone can advise, or at least arm you with information prior to someone coming to look at it.
Reply to Heat Interface Unit Advice needed in the Central Heating Forum area at PlumbersForums.net
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
We have a Daikin Air Source heat pump feeding our hot water and under-floor 8 port manifold heating system. The Daikin has just had its annual...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
Hi, I have a Y plan open vent system, boiler 30+ years old, and requires replacement. My plumber is recommending fitting a new Viessmann 11kw...
