Discuss Heat only boiler to combi upgrade in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Looking for some advice, moved into a detached house which has 4 bedrooms, 1 bath and an electric shower, 14 rads in total.
The current setup which i have no idea how it works, has a heat only boiler which looks quite old and a cylinder in the bedroom cupboard, pics attached
I've had a few quotes, and it has been suggested to rip out the old system and fit an ideal vogue c40 combi boiler which has a flow rate of 16.4 Ltr/min
Will this boiler be more than adequate to do the job? Or is it too big for the house?
I would appreciate your advice
Cheers
It’ll do the job. Depends what you want though. Have you discussed your requirements with your installer?? Vogue wouldn’t be my choice but that’s a different story
Yes it should be up to the job providing you have enough incoming flow and pressure to give you 16lpm.
I think the vogue is a good boiler.
I'm not a big fan of 40kw combis. If you have the requirements for a 40kw combi then get an unvented.
Is it you have 1 bathroom and 1 shower room?
Choices,choices,choices...
In the end it will come down to your personal preference (and if you need the space where the current hot water tank is).
With respect to a large combination boiler, they are only as good as the dynamic cold water flow that feeds it. Be absolutely sure that you have an incoming dynamic water pressure at the point of entry into the boiler that can achieve the boiler output. Whilst you indicate that your boiler is 16 litres/min, that could equate to needing around 18 litres/min at the meter. There is little point in having a combi larger than the cold water feed flow - they should always be sized to your actual flow rates.
My personal preference would be system unvented, but it would be more expensive. However you would end up with a smaller boiler and, in my view, better control of your hot water.
Having said that a properly specified Combi would probably work well for you.
In my area, I rarely come across 40kw + combi boilers that are running at anywhere near their design capacity for hot water
Yep, its one bath and a separate electric shower
The gas pipe is approx 5 to 7 metres away, my previous house had 22mm gas pipe ive been told the gas pipe will need to be upgraded to 28mm. There is no gas fire in the new house but there is a gas cooker
Space is not an issue re costs i'm getting the boiler at a really good price as my friend owns a plumbers merchant. In total its costing me £1350 including the install
If i were to upgrade the current system, what would this likely cost?
New posts
Reply to Heat only boiler to combi upgrade in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Hi all. I recently upgraded our CH system, but rather than the expected drop in gas consumption, Octopus is saying we're using roughly 30% more...
