Discuss Heating comes on temporarily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, in last couple of weeks I've been experiencing problems with my heating it seems to come on and then turns itself off. Other times it works fine .
Hot water has been fine. I was reading up on symptoms online (as I haven't got a clue,hence why I'm here ) and it seems to point me in the direction of it needing an actuator Valve.
Would this be correct or could it be anything else . Cheers .
I would maybe looking at the programmer, usually if a diverter valve is broken then your heating/hot water will stick on. Not always, maybe check both but if it’s coming on randomly then I would look at your programmer.
Reply to Heating comes on temporarily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hello Yesterday my aqualisa shower sharted making a whirring sound and trickles of water came out of itwhen the boiler came on to heat up the...
I have two adjoining cottages, each with an identical UFH system downstairs. Both been going fine for around five years. But for the last few...
