B
buckley plumb
if the baffle has gone fit an external vessel cheaper than new cylinder
Discuss Heatrae Sadia Megaflo problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MegaFlow probably won't honour warranty if you add a expansion vessel, but that's a good idea.
Yesterday, I turned the water of to the entire house.
Opened lowest hot, and lopened T&P until drained.
What confused me is that, although the discharge through the tundish slowed to a drip, it was still dripping continuously even though the hot is drained and the incoming is off!
PS. G3 is coming round again this week. This forum will possibly help me tell him any suggestions.
Have you had the t & p valve changed?
A decent G3 plumber should be able to narrow down to whatever is causing the discharge in a matter of seconds!
Only thing that would cause any problems for a plumber would be if he found it to be a mixer somewhere passing, but couldn't isolate them to test.
Reply to Heatrae Sadia Megaflo problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
