Discuss Heatre Sadia multipoint water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sedgy40
Anything wrong with this?
Yes a lot
Can list if you like
went to change it today there's no drain off and it's heavy around 50ltrs in it
There never are with multi points
just have to grab it and flip it upside down
And would be around 25l
It's 450mm of the floor under a worktop so can't get the grip on it properly as it's putting pressure on the pipe work that's isolated
That's what your knees are for, undo from the comp nuts and roll it into your lap, and flip right way up (pipe at top)
Anything wrong with it (other than installation)
Heater wrong way up
Not secured
No expansion vessel
D1 and d2 wrong
No tundish
No trap on waste pipe
Incoming cold piped to the hot outlet
Heater wrong way up
Not secured
No expansion vessel
D1 and d2 wrong
No tundish
Yeh I thought the multipoint was a horizontal install
There is a expansion vessel just left of pic
Everything else spot on
Whoever installed it must have thought the waste can be used as a tun dish lol
Needs to be on the cold and after the prv
Reply to Heatre Sadia multipoint water heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app 2hrs in morning 2 hrs in evening Any help be much appreciated
