Discuss Heavy designer rad on plasterboard... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassafe
Customer wants there designer rad on plasterboard wall! It's heavy one, I have hung one before probs 50 - 60 kg but that was on a solid wall!
I always understood the fisher type expander / umbrella fixing to be the strongest, when used with the setting tool! But was not too sure about putting this weight on the wall! Has anyone tried it before!? I know the alternative it to cut out & nogging...
i looked online & found these... They claim to take up to 180kg on plasterboard! With a safe weight of 90kg! Surely these could save the day for us plumbers if they are as good as they claim! Anyone used em???
[DLMURL="http://www.gripitfixings.co.uk/product-type-25-2-grip-it-fixing.html"]Grip It Heavy Duty Plasterboard Fixing - Type 25-2[/DLMURL]
Erupto Square Designer Radiator Anthracite H: 1800 x W: 435mm | NoLinkingToThis
Heavy duty fixings and take some weight under the floor on the pipes. Or noggins.
Noggins mate. I fitted the exact one few months ago and they are bloody awkward to hold and lift, the weight made it a whole lot worse.
Go for the plasterboard fixings 2 in each bracket no problem for me, got very similar on my own eggbox plasterboard wall at home and aint fallen off yet
I see they state "safe" max weight 90kg.
Would prefer to open up a section of the plasterboard & screw in some 3x2 or better.
My thoughts are, what if a child later was really rough on the rad, perhaps practising their climbing skills & brought the rad down - who would get the blame?
I've seen those fixings and they look like they would take a good bit weight but with a rad like that, for me it has to be wood but just the top brackets will do it.
Mark it up and cut an 8" strip out the plasterboard. Put 2 dwangs in (noggins), screw the plasterboard back on and tape and fill the joint with fast set. Pipe up the rad and by the time you've done that the filler has set. Hang it on and bobs yer uncle.
Yea I saw a rep with those fixings a little while back, best thing since sliced bread apparently, can't see how that could beat a brolly fixing though when you look at it. If the customer wants that rad I would cut out and put noggins in, better be on the safe side and charge them a little extra for the work.
spring fixings are better than umbrella toggles, but i agree it would be best to noggit.
Would not agree with that, seen them cutting themselves through the plasterboard. Never seen that on a proper sized and set umbrella fixing. But seen them overtightened, bursting the plasterboard over the full area. In specific the cheaper and smaller ones.
Got customers having them fitted. Plasterboard would be second choice. As two of the customers have problems with them resonating. The plasterboard could act like a speaker for that. Though I am sure once the pump gets changed for a modulating one this will stop anyway.
Reply to Heavy designer rad on plasterboard... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone tell me where I can get a walk in shower enclosure glass wall channel with about 50mm - 60mm of adjustment in it? I hired a bathroom...
This post just for interest/comment so please only read if you have spare time. Following on from previous post soldering the elbow connection in...
B
  • Locked
These are beyond plasterboard fixings,plasterer had not put enough dab behind the board so could not go on today,even though we sprayed blue paint...
  • Locked
Nmf 3 last post the radiator views 329 replies 19. 5.79% Fixings Ok you've struggled the double panel extended surface radiator into the room...
  • Locked
HI I have a client who wants a large towel (approx 500mm X 850mm) rail fitted onto a plasterboard stud wall. I am only concerned about the weight...
13K
