Discuss Heights for sanitary ware. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
What heights do you put the timber in for sanitary ware.
I know it varies for different basins etc but is there a generic height for them. When I worked on site I was given a list of heights.
Also what heights do you bring the pipe work out for basins and toilets and corner basins?
All basin noggins go in at 800mm from finished floor for me as standard basin height is 850mm
If it's a semi pedestal, waste at 570mm and hot/cold pipes 100mm above.
Exposed basin with chrome trap. Pipes at 700mm waste at 550mm ( leaving mc alpine adaptor to chrome in wall)
Corner basins, you need to know which one as there is a lot of choice.
If you want to get it bang on get the gear on site and make it up and measure it!! If you guess it's bound to be wrong!
If I can I'll hang the basin then remove
Reply to Heights for sanitary ware. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
