Discuss Hello all nice to be here in the The Welcome Wagon :) area at PlumbersForums.net
Hi - I'm new here though I have found many useful bits of advice in previous threads. I'm a keen (hopefully competent) DIYer and will generally give most jobs a go unless there's a safety consideration. I do like to get it right first time so prefer to research first, then act (or decide it's beyond me and get a professional in) so this forum is gold dust.
Hello and welcome
Hello and welcome
Thanks for the welcome ShaunCorbs.
I'm trying to post a question in the DIY Plumbing Advice forum. I don't think it's anything contentious - it's about a valve - but I get this error.
"Oops! We ran into some problems.
Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator."
I'm baffled. I've tried rephrasing my question in a number of ways but to no avail. Is there something that I need to do as a new member before I'm allowed to post there (e.g. minimum post count)?
In fact, let me see if I can post the question here first as a test - not ideal but I can't think of another way to find out what the offending text is. Second part of the question (first part didn't work):
I need to replace a seized stopcock on a 25mm blue MDPE supply pipe to 22mm copper internal pipework and my preference would be for a full bore lever valve that's a direct fit to both pipes (less prone to seizing I hope).
OK now we're getting somewhere. Final part:
If such a thing doesn't exist, then I'll use a converter on one of the pipes but I want to consult with those better informed than myself first.
:D will have a look at that guess it’s a naughty word 👍
Normally links That are flagged
Same problem with a reply form me, which had nothing spam-like or inappropriate!
Reply to Hello all nice to be here in the The Welcome Wagon :) area at PlumbersForums.net
Hello all, I have just joined, after being pushed into some DIY plumbing. Here is my first plumbing DIY effort. I had a cistern lever that...
Hello, I'm a fairly adept DIYer but I have an issue with my plumbing and not entirely sure what's left to check. I have an unvented indirect...
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
Hello. I hope someone here has the expertise to help. I know exactly what situation it took awhile. On the loft on the 6th floor there is a...
Hi we've just had a bathroom fitted with a mixer tap to the sink and mixer tap with a bath handheld shower fitting to the bath and there is almost...
