Discuss Hello! Can Anyone Help With Strange Problem? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Juney
Hi, I am a newbie, and looking for an answer to what is happening with our water taps/pipes.
The single hole kitchen taps (1/4 turn I think they are called) are fairly new. Recently when you turn a tap on in the bathroom the pipes hum and vibrate, and the tap in the kitchen, although turned off, dribbles water. The same happens when the outside tap is switched on, the kitchen tap dribbles. It doesn't leak otherwise. We once turned off the water at the mains, and drained the taps - this stopped the humming for a while, but it has started again now. Any ideas? :confused5:
Ceramic discs in your kitchen tap are worn, so the vibration caused by water flowing through other taps is making them chatter. New cartridge or new tap, depending on whether spares are available for your tap..
Your water pressure is on the low side. Ceramic disc taps are sealed by the pressure pushing the discs together. A drop in pressure (when you open a tap) causes them to relax and pass a tiny amount of water which makes the noise or starts the drip.
If the taps are old new inserts or cartridges will fix it. If they are new bin them and buy better quality taps or ones with a washer.
When 1/4 turn taps came out about 30 years ago they said you'll never need to change a tap washer again.
They were right as 90%+ of them get binned when they start dripping as very few can be bothered to try to source spares.
Thanks Masood. The taps were cheap, and now we know why! Will look at some new ones :smile5:
You are right, our water pressure is low. Hubby says it is fully on, but the pressure has always been low, and even worse when the farmer has his irrigation on in the summer! New taps it is I think!
Often it is due to the discs inside the cartridge not being tight enough because the washer seal at base of the cartridge has lost its volume. I have fixed a few by replacing that seal. (Also some, but not all ceramic glands have an O ring built in to a metal washer which is sometimes between the disc & final seal washer. This O ring replaced can also fix them.)
Bring back the old type 10/10 tap spindles with packing nut on top & an ordinary tap washer, I say.
Reply to Hello! Can Anyone Help With Strange Problem? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
Hi everyone I have been a plumber for 3 years now, I haven't come across many issues with water hammer so I'm not to sure what to do. it happens...
