Discuss Hello. I worked on an oil boiler that when the outside door is closed the burner goes to lockout. When it is opened slightly it works perfectly. Ha in the USA Plumbers Advice area at PlumbersForums.net
Hello. I worked on an oil boiler that when the outside door is closed the burner goes to lockout. When it is opened slightly it works perfectly. Has been working fine in same situation for 20 years. I replaced the gasket at the burner and replaced the fire board on heat exchanger access door and still no fix. Has anyone any ideas?
Seals would have been my first thought too. What's your FGA readings? Have you checked fan intake and impeller for dirt etc? Possible you have restricted air flow when the casing is on.
Reply to Hello. I worked on an oil boiler that when the outside door is closed the burner goes to lockout. When it is opened slightly it works perfectly. Ha in the USA Plumbers Advice area at PlumbersForums.net
