Discuss Help! Bristan shower cartridge , cant turn off cold water from shower in the UK Plumbers Forums area at PlumbersForums.net
Can anyone help please ?
I am in the middle of trying to clean/ service a Bristan shower cartridge for this shower
Recessed concealed shower
1901 Concealed Concentric Shower Valve | Bristan - https://www.bristan.com/products/mixer-showers?code=n2%20cshcvo%20c
It had started to drip after Thames Water installed a water meter outside . I was advised to clean the cartridge .
This morning I started to try and dismantle it to access the cartridge ,and as I started to do this the cold water started to run through the shower more and so I turned the water off . I got so far and could not remove the cartridge as the instructions are not clear and I cant find it on youtube. I am down to the level in the photos, I cant twist or pull the cartridge out . Am I supposed to remove the small plate surrounding the cartridge by removing the circular discs and parts either side of the cartridge ? Not sure how to do this .....I thought the cartridge would pull straight out when I got to this level
I reassembled it without moving the cartridge but when i turn the water on I cannot stop the cold water at all through the shower heads , when i turn the valve it just wont turn off
Please help , its now driving me mad ! thanks
Betty
As for the controls eg why it’s dripping the left and right brass caps with the two holes in eg holding the valves in that stop the flow
I know I did not assemble it properly in video I was just trying to work out why it wont turn off when it is properly assembled
This is yours
I see thanks , I asked bristan to come out but they said their engineers very booked up .... follow these wrong instructions ! 😡
dont know what on earth to do now
You won’t do it with a spanner sorry to say you will need grips something you can pinch down on the cartridge and wiggle and pull but the cartridge doesn’t have any effect on the dripping these are the top items either side eg my link ref 1 and 2 these stop it dripping / running from the shower head
not sure if a ratchet device would get it out but i think expenisve
but will it stop water flow if i get it out ?
No as that just adjusts the temperature
Tbh it looks like you will need to get a new shower fitted
what sort of grips? , i can buy tomorrow but i have some pliers ?? shall i just pull it out gripping threaded part? if i can... .... if i replace the cartridge will it stop the dripping/ water running out (more than dripping now) when i turn on shower !, unless i turn water off , but need on for other people
this valve is plastic but yours wasnt no idea why
No that’s the temperature side the left and right ones stop the flow
there was nothing wrong with it before!, it only started dripping after Thames Water dug up the road and installed meters ! I was left with two dripping showers ! now this carry on... because Bristan sent wrong instructions and sent me off on wild goose chase " oh you can just clean it taking out cartridge and by soaking in water and vinegar ..." Need a large drink and lie down!
Yep common for them to get grit / other things in your water main when working on it which f ups ball valves and showers
it looks like plastic to me on outside
If you look the part numbers of the thermostatic cartridge are the same so bristan just cheaped out and used plastic towards the end of life of the shower as most parts are discontinued
Reply to Help! Bristan shower cartridge , cant turn off cold water from shower in the UK Plumbers Forums area at PlumbersForums.net
