Discuss Help: Leaking Aqualisa Colt 609 Shower Cartridge #022801 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DIYorRIP
New replacement cartridge has a groove on the back shaft, into which a white cir-clip sits into, whilst my existing cartridge does not.
Should this matter?
Do i have to sit the cir-clip into this shaft before installing or fit without the circlip?
Thanks in advance.
Have you taken the old o rings off the shower mixer.
Are the new o rings in their correct positions.
Have you over tightened. These cartridges need tightening progressively not just one screw at a time.
Hi Chalked
Thanks for the quick reply.
The old cartridge only had a main gasket on the front (approx 5cm diameter). I replaced the O-ring in the main housing which fixes onto the wall.
But the new cartridge look exactly the same apart from the very back shaft (where the filter if) it had a groove for a supplied white plastic circlip. Also new cartridge comes with a small o-ring which i cannot find on the old one.
I fitted the new without the circlip and it still leaked. Hence i am thinking that this is a wrong cartridge or a modified one.
Reply to Help: Leaking Aqualisa Colt 609 Shower Cartridge #022801 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a plumber coming tomorrow to change a cartridge on a badly dripping tap on my bathroom mixer unit. There is no separate isolating valve for...
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
