Discuss Help needed. Toilet tank flash valve access/flapper replacement. in the DIY Plumbing Forum area at PlumbersForums.net
Hello,
I was wondering if anyone knows it this kind of flush valve can be opened to access the flapper to replace it?
The water from the tank is leaking into the bowl one drop at a time and i thonk the rubber flapper os not sealing properly. Can this be ooened in anyway to access the flapper myself to change ir or wouod i need to replace the entire flush mechanism(which means a plumber visit)
This is especially annoying to me as i had a faulty fill valve with heavy leaking and i had a plumber the other day to replace it only to find out the day after that flush valve is very slowly leaking too.
Please advise.
Reply to Help needed. Toilet tank flash valve access/flapper replacement. in the DIY Plumbing Forum area at PlumbersForums.net
