Discuss Help!!!No hot hot water from kitchen tap in 6 years. Unvented ish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I have wanted this issue resolved since we moved in 6 years ago.
INFO
-Unvented tribune premier
Expansion vessel full of air at 2.5psi
-Gush of water when bath tap on then reduces to normal
-Towel rail in bathroom plumbed into partly central heating circuit
-dont think there is an air bubble at top of tank and cant get air back in cylinder
-think the shower is taking excess pressure out of cylinder?
-shower pressure and all taps pressure consistent at all times regardless of kitchen tap issue
-hot water in downstairs bathroom no problems
-hot water in kitchen has lower pressure
-when we have hot water, pressure might be slightly higher
-hard to tell hot water pressure
DETAILS
-No hot hot water in kitchen tap
-situation was fine after the system had been off for a week as we went away all of a sudden problem resolved after 5.5 years.
-we have 2in1 shower..normal and rainforest..
-shower causing the fault 100% as lost hot water(only warm) in kitchen after using shower as shower hardly used.
You need a G3 qualified plumber to work on your unvented cylinder or associated controls. It is illegal for anyone else to do that.
Your pressure readings are wrong and also shouldn't be done unless by a G3 plumber.
Your kitchen tap might be faulty, or have a blockage in pipe feeding it
Hi. Thx for the reply. What pressure is wrong?
I think there is a blockage as well, but why the shower affecting the issue?
Was hoping for a g3 reply at some stage but couldn't post this on unvented forum.
As well, towel rail and stopcock have been leaking as in a little water under valve.
i would disconnect the hot kitchen tap pipe and drain it into a bucket does it get hot if you problem with the tap
Not sure if G3 part of this forum is operating, but is only open to G3 plumbers anyway.
I am G3 qualified, but I can't give advice on unvented repairing or servicing as it is illegal for you to do work as I earlier said and could be dangerous. Unvented cylinders can explode.
Just get the unit serviced (should be serviced once a year for safety and warranty of normally 25 years). A G3 plumber would probably sort it all easily for you.
Post on here on the looking for a plumber and give your approximate location. Some of the plumbers that work on unvented might be local
Wd3 watford.herts
Quote needed as well.
Sorry for misleading you. This forum seems to now have the 'Looking for a Plumber' part of forum removed for some reason that I don't know.
Hopefully some G3 here local to you will read your thread.
Would be hard to quote though, other than basic service or hourly rate, as work needed unknown
Hi. Problem solved. There is a screw valve on both hot and cold supply to kitchen tap. Cganged the hot water valve as suddenly leaking. Now no cold feed to shower unless kitchen hot supply reduced to 10-20%. Dont think its an unvented issue at all.
Reply to Help!!!No hot hot water from kitchen tap in 6 years. Unvented ish in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
