PlumbSafe
I have a breakdown, Keston c36 with no hot water, it was not circulating from pump hydroblock to the plate heat exchanger, so I fitted a new 3 3 way valve, still not moving over to hot water, replaced dhw thermister, still no hot water, the flow switch is working and the boiler is starting up, but won't send it round the dhw heat exchanger. Any thoughts lads. Cheers
