Discuss Keston C36 Combi Errors in the Central Heating Forum area at PlumbersForums.net
hello good forums
Keston C36 combi boiler constantly gives error code e11. (sometimes i see error code E03) From my own research, I found the following information.
E03 Boiler overheat - check that any valves to the heating circuit have not been shut down, no air in the system and that the water pressure is correct
E11The automatic test for calibration of flow and return sensors has failed – check both flow and return sensors are located on the correct pipes and are producing the correct readings
When the reset button on the boiler is pressed, the problem disappears for 3-5 minutes, but the problem recurs.
If anyone has encountered this problem before and solved it, can they please help?
I suspect the combi motherboard
I'm waiting for your help
thank you in advance
I had constant e011 errors on my Keston c36. When i checked the installer status the flow and return temps were the same. I assumed a faulty sensor. As a quick fix i reapplied some thermal paste to the flow and return sensors. It's only been a week but so far so good.
boiler overheat could be caused by a blockage in the pump/diverter valve. Did you manage to get it sorted? I'm dying to replace my Keston boiler but so far no company has provided me with a reasonable quote for replacing it. All are very disruptive, taking half my ceiling down and getting scaffolding, many thousands of pounds.
Reply to Keston C36 Combi Errors in the Central Heating Forum area at PlumbersForums.net
Hi, I am currently having issues with an Ariston Combi A series boiler giving an E08 - "No water in primary circuit" error code, the circuit is...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Hello, We got a Vaillant Ecotec Exclusive Green IQ 835 combi boiler in November 2021 as we wanted the most efficient boiler that modulated really...
2K
Hi Guys, I have been called out to a Keston C55 boiler that had a E36 Fault code, changer the flow and return thermistor but still getting E36...
2K
