Discuss Help with Installation of Grohe 20" F Series showerhead - 27286 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I would really like some help as I am a little confused. I have just got this showerhead and wanted to find out if the normal ibox or rapido t thermostat can work with this. My local plumbing shop has advised me that it is best that I get Hansgrohe Ibox together with a separate shut off valve of 3/4" and also a separate divertor valve to help with the flowrate.
In terms of plumbing, I have just had a megaflo installed and all the plumbing is being done but I want to get it right so I am confused.
Thank you for reading and any help or comments would really help.
Kind regards
Welcome to the forum and I think the advice from the plumbing shop is good
I had called Grohe Technical and they told me that only the Rapido T can work as it has a flow rate of 50l/min on 3 bar.
Do you think the Rapido T could work as this seems a more straight forward or logical option for someone with limited plumbing knowledge.
Reply to Help with Installation of Grohe 20" F Series showerhead - 27286 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
