Discuss Help with leaking mini split please! in the USA area at PlumbersForums.net
Hi all, we have an LG Inverter V, about 4 years old, that is leaking water out of the indoor unit. We had a maintenance person in who both washed out the unit, and as well suctioned out the outside hose, and then sprayed water from unit down through it and seemed to flow OK. But we still have water dripping out of head unit towards the left side (hose seems to ext out on right side).
Gonna try to attach a pic, which seems to show the water travelling down from behind the blower/fan.
The maintenance company believes its probably a faulty/cracked drip tray, and based on the cost of disassembling/repairing it, they are recommending a new unit at the cost of about $1k (Canadian)...
Is the tray (and hose) hidden somewhere above the blower? Other than the hose exiting into the wall on the right side, I cannot see it in the unit itself, assume I have to disassemble (again, more than the units I see on youtube where the hose is just laying along the bottom.
Is there anything else I can try once I'm looking at replacing it anyway? My model doesn't seem to disassemble quite as easy as some I've seen on youtube and I can't find anything online specific to my model (either vids, or even diagrams).
Appreciate any advice!
It’s something to do with condense either the units drain pan is blocked / dirty or the drain isn’t draining
Reply to Help with leaking mini split please! in the USA area at PlumbersForums.net
Hello, looking for some advice with regards to our new wet room shower, we have noticed a leak in the ceiling directly below the shower. We have run some tests and forced water down the waste using a hose and it seems to be fine, we’ve placed the hose in different areas around the shower and...
Bit of a long video here, but I'm really hoping someone can help. We clearly need to get someone in to fix the leak, but meanwhile I'm concerned where all the water is going to. There is no water damage in the surrounding area. Walls and floor seem perfectly fine. I can't work out where the...
Hi, I've been having trouble with my boiler leaking for months. We thought we'd fixed it last winter as haven't had any trouble throughout the summer but in the last week or 2 it's leaked again, we had several people out to look at it but no one fixed it. Tonight we've had someone else look and...
1K
My water stinks. Smells musty. I installed a Whirlpool water softener mid February of this year ('23) and it's smelled ever since. So here's the story: we live on a farm in southeast PA. Our well is 60' deep with the water table around 10'. Two houses supplied from the same well. One day I...
G
Hy all, So i noticed the corner in the living room was getting damp. investigation showed that the corner skirting board that goes around the boxing in of the SOIL pipe was rotten with mould and the carpet was saturated. Obviously been going on for a long time. I dried the area out. I then...
1K
