Discuss Help with leaky valve under sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
The pipes beneath my kitchen sink started leaking - lots of water was streaming down. Have used colours in the pic attached:
- The red box is where it's leaking from
- The green box is the valve that we turned off to stop the water leaking. I think the main tap (i.e. the silver thing on top of the sink) is ok
Does anyone know what we'd need to do to fix this?
Thanks!
Strange why it's only just started to leak
Might need a pinch up with a set of spanners
Thanks guys - will try tightening it. It hasn't been knocked but we have had guests that are quite strong armed with turning the main kitchen sink tap on and off - would that affect it? Think it might have been dripping for a while but I hadn't heard it until yesterday because it's inside the cupboard, and there is a bit of mould on the back wall...
Do you mean it was running down the pipe? Does the water trickle out of the mixer tap and run down the spout? If yes to these, could be poor seal between tap/sink and tap needs new washer's in.
Is the tap qtr turn (ceramic disc) or screwdown type?
Undo the silver nut above the valve & lift it clear to check that the olive is still in the correct position before tightening it any more.
There should be approx 10mm of copper tube showing past the brass olive, if there is you could try a couple of turns of PTFE around that pipe sticking out before you push it back into the valve & tighten back up. Only wants another half a turn once it is tight.
Might be a silly question, but how can we get the copper pipe out to wrap the olive with PTFE? It looks like the pipe is fixed to the tap at the top and another pipe network at the bottom.
There should be enough spring in the pipework to pull it apart.
Don't forget you will need another large spanner to hold against yourself as you tighten it back up.
You sure it's not coming from above either where the copper tails screw in to the tap body its only a o ring seal or even where the tap seals to the sink top again only a o ring and can move if treated roughly ? . Kop
Reply to Help with leaky valve under sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
