Discuss Hemp and PTFE on iron.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Commercal gas alot to take in but very rewarding good for you bud , gas screwed pipework i use loctite 55 or gas tight paste or weld it or i did ha ha
Screwed pipework has now taken a back seat as it to labour intensive , and costly crimp is the way its going carbon steel , copper ,stainless , pex theres a system for them all Gerberit and yorkshire are just the main ones regards kop
yea ive done a load of crimping up to 54mm, its certainly quicker, less smelly and you dont need a ton of the same gear like the screwing machine, chain vice (though still useful) and all the other stuff that goes along with it.
another thing the chap does I worked with is leave all the hemp on the fitting wheras I would always get a hacksaw blade and clean the joint up completely, just the way I was taught.
when we did gas, we just used boss green IIRC.
Depends on what else in the van is smelly I guess. :rolleyes:
my van almost always smells of kero these days :D
Only use carbon steel press on a sealed system else you will have it rotting through in about 5 years :D
When i worked on commercial projects its all we used the council and health authorities would not allow hotwork after a team of roofers burnt a school down in norfolk .
national trust also, no hot work, we have to press everything or push fit etc
Agree with you bud i did some servicing and repair work for them nice work and paid very well, but no hot work regards kop
My jointing methods are as yours screwed heating pipework up to 2" hemp and paste - then cleaned off with a hacksaw blade - 2 coats of red oxide primer - 2" or above welded or crimp , gas services Rocol gastite paste or locktite 55 up to 2" above welded cheers kop
just for my own interest this.
I've always jointed screwed iron on heating systems with hemp and paste (boss white, green, jet blue, blah blah) but I worked with a guy recently that was running hemp onto the thread as normal but then adding a couple of wraps of PTFE, no paste.
I've never come across this before, anyone been taught to do it this way ?
Hello jay I have been a Plumber for 40 years and have used Flax or Hemp and Boss White This was on 1/2 To 4 inch GB Not likely to have a leek but use that PTFE Tape and go back a 1/4 turn And it will Sod If you screw a thread on GB most of the time there is small gap on the screwed thread so if you flax and boss white this joint and screw on a fitting prove this for yourself unscrew the same fitting and if by magic the gap in the thread is gone this is what the hemp and boss white are supposed to do as well as give you a water tight joint
I just wondered if anyone remembers a liquid jointing paste called heldite we used to put this on with hemp black or dark brown horribly sticky stuff but never any leaks mind you couldn't get apart very easily if you needed to .
I use heldite still, cos I'm an oily ;)
Reply to Hemp and PTFE on iron.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
