Discuss hep20 help needed. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gasso
is anyone experienced with hep20 plastic 22x10mm 4port manifolds.they differ from the other fittings (bends ts etc)slightly, are the10mm ports demountable.ive tried and had no joy.help!
I though all the Hep2o range was supposed to be demountable... Have you got the proper key for it?
got the set.dont even need them to remove pipe from bends ts etc.but the manifolds have different ends.
Sounds like your using a mix of fittings, as far as I know all Hep fittings are white now and all require the demounting tool to remove pipe from them? You got a photo?
Reply to hep20 help needed. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
