Discuss Hep20 Pipework and Osma Gold fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mopane
Hi, a continuation of my replacement shower planning...
I have plastic Hep20 Barrier pipe leading down to my existing shower unit. There is an Osma Gold elbow fitting that brings the existing (very short) copper pipes out of the wall. I will need to replace these tails with some longer copper pipes for the Bar Valve Installation kit I need to use for the new shower.
My understanding is that I will need to cut the Osma Gold (I don't have the special spanner needed to loosen these, and understand they cannot be reused anyway) fitting from the Hep20 pipe and fit new elbow connectors onto this, and the new copper tails out the other side.
So my question is, what pipe inserts can I use for the Hep20 tubing, ideally ones that I can buy in small volumes locally. And should I use compression fittings rather than push fit (I think the latter is a controversial subject)? I have an unvented mains pressure hot and cold water system, if this makes a difference.
Thanks in advance.
Reply to Hep20 Pipework and Osma Gold fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
