Discuss Hi I am thinking to replace my ageing Alpha CD24R with a Bosch in the Central Heating Forum area at PlumbersForums.net
Hi I am thinking to replace my ageing Alpha CD24R with a Bosch equivalent, I have a few quotes which seemed fair, until today we had a company turned up, he really had a good look round. Far longer than the others, (one i had to send pictures ? And he quoted me the pics that I supplied?) He informed me that the copper pipes going to the cylinder are 22mm and the Bosch requires a 28mm . Connecting directly to my old pipes , I may/will get a problem with the heat exchanger at a later date. he recommended using another company boiler . he also told me that with the 22mm pipes the system will not as efficient . We have been in this for 3 years and I have noted that the radiators get warm not hot. Is he honest , or is he toting for more work?? Could any one clarify
Don’t know what he’s talking about as the Bosch does / only have 22mm connections
Only thing I can think of if he’s upgrading due to maybe down the link going for a air source heat pump etc
Reply to Hi I am thinking to replace my ageing Alpha CD24R with a Bosch in the Central Heating Forum area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Hello, I have just had my 15year old Grundfos UPS 15 50 replaced with an Alpha 1 and the Alpha 1 seems quite a bit noisier than the the old one, I...
Hi folks, i've just moved into a property last month and begun to take note of things that may need attention. One of which is the feed to a...
Hi I've just had my annual maintenance check on my boiler (in title), it will be 8 years old in May this year and is (I think) still under...
2K
