Discuss Hi, I have an ideal Instinct boiler, its nearly 2 years old. I have started having problems with low pressure about a month ago. in the USA area at PlumbersForums.net
Hi, I have a two year old Ideal Instinct boiler that has been problematic for about a month with low pressure. A plumber came out twice and reset it and it seemed ok but its started loosing pressure again a couple of days ago. He has been back and blown something up in the boiler which he thought would sort it but within half hour it had dropped again. It is currently working on continuous setting but it won't come on in automatic mode and I'm starting to get problems getting it started if I turn it off. The plumber is too busy to come back and going on holiday tomorrow so I'm in a lather as I need it sorting for Christmas!! there are no obvious leaks anywhere. any advice appreciated.
Outside there should be a copper pipe is this dripping should be directly external of the boiler
As it’s a couple of years old and you can’t see anything best to call ideal out to check the boiler
Reply to Hi, I have an ideal Instinct boiler, its nearly 2 years old. I have started having problems with low pressure about a month ago. in the USA area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
