Discuss Hi iam matt I've a question on a gas boiler. Any one help me? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matthaw86
Hi I've a current problem with a gas boiler and looking a bit of advice. It's not a combi just a flow and return from boiler with the hot water cylinder plumbed from the main heating pipes. Boiler seems to hit around 95 degrees tops then goes out on high limit. Once reset it does the same process, does not cut in and out with the stat. Would this be stat failure or anything else?
Many thanks
Matt
This would be a read the forum roles on the first page Matt. It's for your own safety.
In summary "We cant condone giving out gas safety related advice to non qualified people this includes all aspects of gas installation and repair."
Gas, Gas Appliances, Boilers and Central Heating Advice.
Any posts relating to gas, gas appliances, boilers and central heating should be posted in their relevant sections and not in the public domain.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. http://www.ukplumbersforums.co.uk/im...-gas-engineer/
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
notice gas safety related advice
Call a qualified engineer
or you could check the pump is working seeing as its not a combi and the chances are its in your airing cupboard although im sure the airing cupboard police willl be along shortly
Reply to Hi iam matt I've a question on a gas boiler. Any one help me? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
