Discuss High gas bills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
skaly
Hi All
I took a call from customer saying gas bills very high, The boiler is a HEATLINE S2OS LPG. I am going out to it at the end of the week .What checks should i do ?
So is mine I reckon its gonna cost me an extra £10 a month on gas this winter.
They do realise that gas prices are sky high at the moment so their bills will be high.
Hi All
check he's got enough cash to pay for your call-out, he might have spent it all on LPG :smart:
Hi All
Gas rate the boiler and as Bod said "check for leaks"
This time last year I Serviced boiler . Soundness ok / Burner Pressure ok . I did not gas rate it. There is nothing more i can do this time round or am i missing something?
Fully service the boiler, strip it down and clean everything, get a small smoke pellet to check Heat exchanger is clear.
Check all rads are warm, no cold stops.
Check their gas bills, have they changed supplier? Has the supplier increased price?
How often are the changing cylinders?
Is it set-up for LPG, but on NG?
Using Butane or Propane?
Gas rate it and everything Orry said
Hi All , I called today carried out a soundness all ok, Cleaned combustion chamber, Set the burner pressure (which was ok) Gas rated it 20kw. I took a look at there gas bill 3 months use 89m3 early in the year. Last 5 months 19m3. Looks like they had it on full whack until they got there bill. THANKS to ALL
you mean the first reply , mine was on the nail :) fancy that lol
Spot On Bod. All the calls up to today saying not using it more than usual, I asked to see the bills , there in black and white.
Reply to High gas bills in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
  • Sticky
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from...
