- Messages
- 234
If you have a fein or any other multi tool there blades are very expensive, keep the old blades that are worn and weld hack saw blades on the end.
Discuss Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Little tip:
Have a system of storing your everyday tools that you repeat every single day.
I have always worked this way, but did some work with another plumber the other week, and realised he didn't do as I do.
It's all about repetition so it becomes second nature. I clip my van key with a carabiner to side as soon as I leave the van. Phone goes in pocket on left thigh. On my key ring I have a vent key, a meter key, and a washer that I can use to isolate ballafix valves in a pinch.
All my tools in the tote back go back in the exact same place every day. So does everything else in the van. So when I need something, I know where to place my hands to it straight away. How people don't work with this system is beyond me, but if you are one of these people. Adopt a system and stick to it. I do it as by nature I am a skatty forgetful person. So if I don't have a system I end up leaving tools behind, losing stuff, and generally more stressed.
im with whn1 on this gotta look alright from a distance...
Got two new boys, finally got them to understand clean the gear away and stack it besides the van but never load it!Yeah, lads are a bit good at upsetting the apple cart, but I always explain that I'm clearly a weirdo and must maintain the system. Then they know it's me being a gimp but that's how I have to work.
That said, got out my socket set today. Everything all over the place. Last person to use it? Apprentice.
i do fit them unlevel. Obviously telling the cust or whoever the reasons. a level rad under a drunk sill looks awfull and a rads part of the astheatics of a room. gotta agree to disagree bud.never fit a rad out of level unless specifically told to by customer or agent you cant argue with the bubble if they want it changed afterwards then they pay if you fit it out of level and they dont like it then you have no argument cos they will always say its your fault
I always thought a reciprocating saw was over rated until I discovered LENOX blades it turned the saw into a great tool was really suprised at the difference which was what the guy at the fixings company said when he gave me one to try he said you will be back for more !
The main frustration with Plumbers Mate centers round how to manipulate it. Nobody doubts it works when applied correctly but it's just properly hard to use. If you've got to return a WC to a pre-existing dodgy-looking pan connector you've not the time or inclination (or available stock) to replace, a ring of plumbers mate round the WC spigot (properly cleaned with an abrasive pad and some wipes first - oh joy) will sort it every time.
The way I've found that works is to never handle the same mm of it for more than half a second at a time. Keep it moving from finger to finger or it will stick to you. When you've got it where you want it start proding it at a million miles an hour, really quick, soft, finger moments pressing and persuading it this way and that. It starts to mould to your will rather than act like an autonomous little beggar. Bit like the wife.
Don't know how we got onto plumbers mate, but back when I used that, which was a long time ago I did a couple of things.
I mixed a ball from a new tub with a ball from an old tub to give a better workable consistency. If I didnt have half an old tub, I would form a ball and roll it out on a bit on newspaper to remove some of the excess oil.
Haven't used plumbers mate for years, and don't see myself using it ever again!
Plumbers Gold on the other hand. Always carry a tube in clear and white. Lovely jollop!!
theres no oil in plumbers mate your thinking of putty
Think you have the repair one there Tamz the standard old style isBet you never knew it was like this! I didn't but i don't use it so have never looked at the coshh sheet.
http://www.bostik.co.uk/sds/download_sds/PlumbersMaitQuickLeakRepairPutty-English/04415314.pdf
i like this line best seeing as it is designed for use on waste jointsThink you have the repair one there Tamz the standard old style is
[DLMURL]http://www.indanc.com/downloads/pdf/Evo-Stik/Plumbers_Mait.pdf[/DLMURL]
Very dangerous stuff this one LOL
one just popped to me today (im sure others will have used it plenty like as its so obvious but hey) when replacing a towel rad or standered rad upstairs and you cant find a drain off without lifting a trap or 2, find a downstairs rad has modern bleed valves you can drain straight into a large flexy tub through the bleed valve nice and easy allthough this wont allways work if all rads have been dropped from above
Far better to isolate valves and remove vent plug and replace with a compression coupler with a bit of pipe on it then open valves and fill a bucket or stick hose on pipe.
Reply to Hints, tips & secrets of plumbing - No Banter please! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
