Discuss Hive Heating & Hotwater install to Vaillant Thermocompact VU GB 242/1 in the Central Heating Forum area at PlumbersForums.net
I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler.
It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer)
This programmer is connect to a terminal strip using 345 (three connections).
The hive install manual shows the dual channel receiver wiring with pins 1(Hotwater off), 2(heating off), 3(hotwater on) and 4(heatingon), but I can figure out where these potential 4 wires go to on the terminal block on the boiler?
There is a hardwired thermostat in the hallway, but I can see where those wires go into the boiler, so I set that thermostat to maximum to keep it on
I am attaching the pictures I have taken and the manuals I have been reading for the wiring diagram.
Any help appreciated
Nitesh
Reply to Hive Heating & Hotwater install to Vaillant Thermocompact VU GB 242/1 in the Central Heating Forum area at PlumbersForums.net
