Currently reading:
Hole in outdoor waste pipe from kitchen sink
Discuss Hole in outdoor waste pipe from kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Papalazarou1977
We are having a deck fitted and so wanted to get rid of the ugly pipe which comes from our condensing boiler out to our waste pipe from our kitchen. I have removed the condemning pipe but we are now left with a small hole in the side of the waste pipe and I am not sure how we are best to seal it. The deck panels will be over the top of the hole and there is currently a slight leak from the hole when we run the tap down the drain and so we don't want to leave it. I was thinking of using some water proof tape to seal the hole but wasn't sure if there is a better solution. Any advice anyone could give would be appreciated.
Many thanks,
Jamie.
Cut the pipe out and replace it. What have you done with the condense from the boiler?
Thanks for the reply Mike, the problem with replacing the pipe is the frame of the deck is already down and it is right in front of where is hole is so it is going to be hard to replace I think. As a makeshift solution, do you think waterproof tape will work? There's no pressure coming from the hole, even when I run the tap in the kitchen on full, it just trickles out so I am assuming the tape wil deal with that kind of pressure?
Regarding the condensing pipe, we are routing it inside so it runs to the waste pipe through the house.
Jamie.
Reply to Hole in outdoor waste pipe from kitchen sink in the Plumbing Jobs | The Job-board area at PlumbersForums.net
