Discuss Hole size for countertop... in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
mutley racers
Subscribed
Morning all. What size diamond holesaw do you use for drilling the hole in a quartz countertop for a basin waste to go through? I have a house where they installed all the basins wastes with the nut and washer tightened onto the bottom of the worktop and not the bottom of the basin. Hope that makes sense.
Also, recommend a good holesaw make.
Cheers
I’m guessing your having a problem with the length of the threads ?
Can’t you get a tap with the threaded rods and just cut your own ?
I need to take the lot out and cut the holes so that the hole waste and flange nut fit into the countertop? Rather than fix the threaded waste through the countertop and tighten the back nut onto the bottom of the countertop. Hope that makes sense.
Basically, what size is the back nut to a 11/4 waste? Should just get out of my van and measure it. Around 56mm. So to have clearance I would need to drill a hole around 73mm?
Yes but tbh I would get a worktop specialist in to cut the holes as if it cracks your fecked
You can drill it ok with a diamond hole saw.
Go slowly and don’t use much pressure.
Lubricate and cool with water. ( if it heats up Quartz can crack)
Go really slowly at the end and with almost no pressure to avoid breakout.
Probably need removing and re-fitting with silicone between flange and basin - that’s all…
A few minutes each , not what you are proposing, and also no risk of damage.
Reply to Hole size for countertop... in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has...
