Discuss Honeywell VA8200A001 TVR Service Tool Hire in the Plumbing Tools area at PlumbersForums.net
I need to replace 13 TRVs due to sticking issues, I saw that Honeywell do a tool to remove and exchange the TRV inserts', this will save me draining the system and saving time, anyone know where I could hire one from?
Cheers
Tbh the cost of the tool and inserts depending on the system outways the cost around £500
What brand of valves do you have?
Some valve manufacturers have their own tools for removing the valve insert on a pressurized system.
Some are quite reasonably priced too.
They are Honeywell VT15BG, I have relooked at the IMI Hydronics Insert Tool and it works with a 19mm Hex head which is the same as I have and at a much more competitive price.
Thanks for giving me the push to research other options :)
Reply to Honeywell VA8200A001 TVR Service Tool Hire in the Plumbing Tools area at PlumbersForums.net
