Discuss Horizontal unvented - secondary return in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Is it true that a horizontal unvented must have a secondary return pump fitted for destratification?
@chris watkins
@chris watkins
I don't think they have to but it probably helps to achieve more usable hot water.
You don't actually need a HW return system it might be more suitable to just fit a small circulator between the hot outlet from the cylinder & the cold feed with a suitable check valve. This could be powered from a call for domestic hot water (if it is an indirect) i.e. brown on zone valve, in that way it would be de-stratified only when it is being heated, should lead to a greater volume of usable hot water.
Reply to Horizontal unvented - secondary return in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Silly question (and might already been asked 100rds of time) - I am specifying a circulation pump for the hot water secondary (circulation) return...
1K
R
Wb 4000 recently installed, and just balanced the rads with around 16 degree delta across most rads. I'm trying to make sure that the return...
Return temperature
R
Just looking at getting an unvented cylinder. Screwfix do an RM cylinder called Prostel. Anybody had experience with these. £830 for 250l horizontal.
Anyone know of preplumbed horizontal unvented cylinder apart from the Telford Tempest. My plumber has said they save a lot of time but he's...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element...
Peter M
