Discuss Hot water cylinder with immersion tripping rcd. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys.
I have a newish (4 years old) hot water cylinder with 2 immersion heaters fitted.
It has worked fine but yesterday when switching it on it tripped a rcd. I have disconnected the mains from the element put it in terminal strip and tried the switch again and it doesn't trip so I would guess at the issue being within the immersion.
Could this be the thermostat or is it likely to be something else. Thanks in advance
Cheers for the replies. Will swap the thermostat over tomorrow.i thought it might be the immersion. Going to be a absolute pain draining the tank if the immersion does need changing.
The drainage point is very tight to get to.
Try the stat you maybe lucky.
I am assuming this is an unvented cylinder , if it is , just to make you aware you have to be qualified to work on these cylinders .
How do the "disconnected" cable cores look?
On older installations the heat from the immersion & tank will make the insulation deteriorate and then the live or neutral could come in contact with the cpc or metal parts .....
Thanks again.
Iv checked the resistance. I have open circuit on the thermostat (grabbed a new one from plumbase) that changes to 0.6 ohms when temp is set to 65.
On the heater element I have 19.6 ohms.
Murdoch The cable looks fine.
Both of our elements don't work now. One went about about two years ago called the guy who fitted the new cylinder when it was Asked him to come back and I'll pay for what needs doing he said just use the other one.
It's been bad luck from the start. Electrician who come to connect it nearly set our house on fire. He plugged it into a plug top timer. Me and my partner were sitting downstairs and could smell smoke. The whole thing melted.
This is what it is. Probably makes more sense to you than me.
It's a vented direct cylinder.
If you have the Economy 7 (or similar) electric tariff, the lower immersion would be connected to this to heat up the whole cylinder at cheap rate (round about 1/2 normal rate) electricity. The upper immersion would be connected to the normal tariff electricity supply, and used to re-heat the top 1/3 of the cylinder if you ran out of hot water. If you have been using the top immersion only, then if you do have Economy 7, you've been paying twice as much as you need to to heat your water.
I'd advise you to have the cylinder drained and both immersion heaters replaced with good quality (Incalloy or Titanium) ones, then make sure that each is properly connected to an appropriate electricity source.
Reply to Hot water cylinder with immersion tripping rcd. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
I have read of hot water cylinders being heated with a dual element immersion heater. The main principle being that a shorter element heats the...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
