Discuss hot water gravity slows to nothing in the The Welcome Wagon :) area at PlumbersForums.net
M
Mark OD
My gravity fed hot water slows to nothing over 30 seconds. when tap turned off for 5 mins, tap will run again for 30 seconds etc.
I have tried the mixer tap/air lock trick about 10 times now and still not fixing.
I have drained the HW tank a little so I can inspect the 22mm out pipe at top of HW tank for scale etc: it is clear.
I do have a MagSafe but I'm guessing this is not an issue cause its on CH
I also have a shower pump, and I don't know if this could be a cause to my problem, which happens on all HW taps, upstairs and downstairs.
Thanks in advance for your advice
Mark
Definitely sounds like an airlock.
Easiest is get a wet vac on the hot to the bath and keep sucking until the hose is thrashing around like an upset snake , then pull the vac away and hee water should continue from the tap at full force. Let it run for a bit. Then shut off , wait and Ghent turn back on - it should be fine but if not just repeat for longer.
Reply to hot water gravity slows to nothing in the The Welcome Wagon :) area at PlumbersForums.net
