Discuss hot water low flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
webbm
Hi
I have potterton he 28 since yesterday the hot water flow through the boiler is very low and make whistling/hissing sound coming from the boiler.
I turned the boiler off and the flow is still low on the hot tap and still makes a hissing sound. Tried all the hot tap throughout the hose and it same issue.
Cold water flow is is still good and central heating is working fine any ideas what it could be?
Think there is one thing you can try. The cold pipe should be the second pipe in from right. Also look in the instructions and look up how to remove the mains cold inlet filter. I would be very upset and disappointed if you opened the boiler case. Your not allowed to and be risking your family!
DHW Filter (Fig. 79)
13. If the flow of domestic hot water is diminished, it may
be necessary to clean the filter
found the above is it worth asking a boiler engineer to check it for me because the one I called out was not sure what the problem was he said it could one of 2 parts and would he need to change both to find out the cause he wanted £320
A decent Gas safe engineer should be to identify the fault without having to resort to sticking parts in hoping it would work Why not post up a request in the looking for an engineer section of the forum (link is below)with your location, you are more to get a decent engineer to come and have a look and advise you correctly.
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to hot water low flow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
I have a very strange issue with my BAXI 105e DHW. if i turn on the hot tap the pump starts and demand for DHW is shown, after a some seconds it will show an error, 60 degree, pump or flow. Well switch the tap off wait maybe fifteen seconds turn tap on and low and behold hot water. If after a...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
Hello, I’ve been doing my first refurbishment is a two bed flat with a bathroom and ensuite . Learnt a lot and been grateful for input’s especially from Shaun. The customer had ordered swan neck mixer taps for kitchen, bathroom and ensuite. On installing then all the hot water flow is none...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
