Is it something that commonly occurs?That makes sense. Do you think any competent gas fitter would be able to diagnose my issue fairly easily?
Discuss Hot water only works when more than one hot tap turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I would say yes, where abouts are you located? Maybe someone on here is local to you.That makes sense. Do you think any competent gas fitter would be able to diagnose my issue fairly easily?
WirralI would say yes, where abouts are you located? Maybe someone on here is local to you.
Some people don’t know about gas safe or getting a qualified engineer. Hence the advice we offer. We can discuss other topics, we could also steer you if we thought the problem was nothing to do with you boiler. Ps it’s not fear it’s illegalApologies if this is anally question but doesn't that rule kind of render this forum useless? If nobody is allowed to suggest what the answer to a problem might be for fear that they might try to fix it themselves then surely anybody that is not qualified should not be allowed on the forum as the answer to any question would always be the same. Ie get a qualified gas fitter to look at it.
Reply to Hot water only works when more than one hot tap turned on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
